Help removing the emergency brake line.
    Question Help removing the emergency brake line.
    On my 66 mustang, I am having trouble disconnecting the emergency brake line that goes through the backing brake plate.
    It has a clip that holds the braided line in place and I am not able to disengage that clip so the line can be removed. Can you help me with this problem?
    Paul Adams
    sure. use a small hose clamp to compress the fingers OR use a box end wrench to slide over them & compress.
    aka C7ZZ-F
    Regional Director for Bluegrass Mustang Club
    MCA Gold Card Judge 64 1/2-66
    Boy, you are good. the Clamp worked perfect and they are off now.
    Thanks,
    Paul
