sure. use a small hose clamp to compress the fingers OR use a box end wrench to slide over them & compress.
On my 66 mustang, I am having trouble disconnecting the emergency brake line that goes through the backing brake plate.
It has a clip that holds the braided line in place and I am not able to disengage that clip so the line can be removed. Can you help me with this problem?
Paul Adams
aka C7ZZ-F
Regional Director for Bluegrass Mustang Club
MCA Gold Card Judge 64 1/2-66
Boy, you are good. the Clamp worked perfect and they are off now.
Thanks,
Paul
