Results 1 to 9 of 9
Door Panel problems
    Wayne Baker
    Martinez, GA
    Angry Door Panel problems
    The covering on the driver side door panel is coming detached. Is this a common problem and is there an easy way to repair this?
    Quote Originally Posted by 60752 View Post
    What year Mustang is it?
    Wayne Baker
    Martinez, GA
    door panel
    Quote Originally Posted by MrFarmdog View Post
    I have a 2007 GT Convertible. The black trim is what is coming loose. I have thoughts of using super glue orsome spray adheasive. I just don't want to make it worse. Thanks for any suggestions.
    I have a 2007 convertible as well. To be clear are you talking about the insert on the door? Looks like leather? Is that what is coming off? do you have any pictures?
    Wayne Baker
    Martinez, GA
    Door Panels
    I have parchment (tan) interior and the door panels have a black insert that looks like leather. It has come "unglued".
    First thing I would do is check your warranty. Stuff like this should be covered if it is still under warranty. Next I would take it to an upholstery shop and see if they can repair it. Should be pretty easy to repair.
    Wayne Baker
    Martinez, GA
    Thumbs up
    Thanks for the advice. I will check the warranty but am sure that it has expired. The upholstery shop is a good idea. Like I said, I didn't want to make it worse than it is.
    door panel repair
    hi, make sure the shop that does the repair adds a leather bead all around the door insert. if you dont the repair will not look factory finished. had to repair my 07 gt. cost was 45.00 per door.
    Wayne Baker
    Martinez, GA
    Lightbulb
    Quote Originally Posted by southern stang View Post
    Thanks for your input!
