Page 1 of 2 1 2 LastLast
Results 1 to 10 of 20
MCA Online Judging System - Take a test and become an MCA Judge!
    Article: MCA Online Judging System - Take a test and become an MCA Judge!
    Wher is the test for 71 - 73 Concours?
    64 1/2 D code Coupe
    08 Shelby GT500
    Jim
    Brockton MA
    71-73, 74-78, and early Shelby's will be up soon.
    Mark
    Greer, South Carolina
    Need help signing in to test.com
    Steve
    I attempted to create an account test.com in order to take a judges test and I was unable to. Here is the error message:
    "Sorry, the Account Code and Join Passcode combination is not recognized. Use the code that was provided to you. Please try again."
    I understand I am supposed to use my member # for one or both of these codes (which I did). Please advise. Thank you for your assistance.
    Mark C 2013 Vice president, Foothills MC
    1970 Mach 1 T-5 (DSO 91)
    0F05H172XXX
    1 of 86
    Quote Originally Posted by MarkCordery View Post
    Steve
    Mark I corrected your issue. Check your email.
    i got the same error message- Thanks
    Just took the 1969 - 1970 Concurs test, Thought I knew a lot but I need more learning!
    Thanks for the oportunity to test myself.
    Had the same issue as Mark above. Can you help?
    Thanks -
    nate
    Quote Originally Posted by RudeRoush View Post
    Thanks -
    nate
    Nate the issue was that you had a space in your user name. This causes test.com to choke. I removed the space and now you have access.
  10. #10
    All, we also have noticed issues with Internet Explorer. IE will open up a new browser window where you are not logged in and that will cause you to get an access denied. If that happens log in again and then paste this link into your web browser
    www.mustang.org/send2test.php
    Also when you get into test.com make sure you allow popups for that site because once you start to take a test the test will open up in a new window and if you have popups dissabled then you will not get the test.
