camshaft for 302 for road driveing
    Red face camshaft for 302 for road driveing
    HI every one , i'm a new ford owner and just got a 69 mustang and now getting a rebuilt 302 for it and would like to put a light cam in it nothing big but so it will make a litte rumble , can some tell me what is the best one and the lefter should i keep the same ones ? and can i just put it in and run it with the stock stuff reminber i'm new now guys so go slow please .
    If you are looking for just the sound of a big cam, you might look at Comp Cams thumper series. They have a little bit more of valve overlap that creates the sound. The balance of your exhaust system components will have more of the effect than the cam. Small block fords don't respond with the same type of cam sounds as your buddies with the small block Camaros.
    65 Kcode coupe 5F07K, Retired MCA Modified, 347 drag car, 10.54 @ 132.8mph
    66 Convertible, 289 Three dueces and a 5 speed, MCA Modified
    2001 GT convert wifes daily drive
    Music City Mustang Club
    MCA # 29208
    Quote Originally Posted by kcode View Post
    You'll get lots of comments on this I suspect.
    Your best bet for a little more horse power without lots of lope would be the Edlebrock Performer Plus. I believe you can run this cam with stock valve springs and not have to heavy up the top end...I put a comp cams nostalgia 271 cam in my fastback....this cam is old school and requires heavier valve springs, but the sound is K-code all the way....and the performace is very '60's....
