Your website account should be linked to your MCA record. This recognizes you as an active MCA member and gives you full access to the MCA website. If this is done you can find your MCA number and expiration date when you click on Edit MCA Account Details. Navigation to that page is listed below.
My Account -> Edit MCA Account Details (under MCA Membership - left side)
If you are an active MCA member and there is no MCA number listed then your website account is not yet linked to your MCA number. This could be because when you joined the website you did select the option that said you were a current or former MCA member. You may also notice that under your user name is says you are in the ENTHUSIASTS group instead of MCA MEMBER. If you are in the ENTHUSIAST group and are an active MCA member then please do the following:
Log into the website and click on MY ACCOUNT (upper right) and then look on the left side about half way down under MCA MEMBERSHIP you will see a link for ALREADY AN MCA MEMBER? Click that and enter your MCA number and Expiration date and click Join. The only caveat is that when you put in your expiration date if the one on the card does not work then try one month before or after the one on your card.
If you have problems send an email to the admins using this link and select WEBSITE as the reason for contact.
http://www.mustang.org/misc.php?do=form&fid=2
